1 - 1 of 1 Posts
Premium Member
https://www.kseriesparts.com/HD-KPRO-ECU.html
Hondata KPro4 (Version 4) is a fully programmable ECU for 02-04 Acura RSX (DC5), 02-05 Honda Civic Si (EP3), and any K Swapped vehicle. K-Pro is a must have to get maximum performance out of your k-series engine.
  • This is a completed K-pro'd ECU that is ready to be plugged in with no wait or downtime!
  • USB connection for speed and compatibility
  • KManager Windows based software for parameter and table editing, calibration uploading and datalogging.
  • Many built in calibrations for common engine combinations
  • Built in datalogging to a laptop
  • On board datalogging memory (2 MB memory, 10-110 minutes datalogging)
  • Adjustment for different sized injectors, with overall fuel trim.
  • Configurable for any MAP sensor (to 5 Bar and above)
  • TPS based table lookup for ITBs
  • Engine protection from over boost and lean protection.
  • Launch control with anti-lag
  • Three multi purpose outputs for nitrous control or similar
  • Supports lambda tracing from the stock wideband o2
  • PWM output for boost control
  • Most OBDII features may be disabled for race vehicles.
  • Base tables are supplied for the RSX Type S, RSX Base, Civic SI and Integra Type R engines. These tables have been dyno tuned.
1 - 1 of 1 Posts
