1 - 20 of 20 Posts
is there a difference between a 05/06 type S headlight and a Base model 05/06 headlight?
need answer asap!!!
are you sure? because i have basemodel and my stock headlight has an orange light inside it, i found a type S headlight on ebay and it is all chrome with no orange inside it.
Firefighter/Paramedic
no, there is no difference. the reason the lights on ebay look different is because they are shitty ebay lights.
No difference at all.
/thread.
Retired OG
The stock 05-06 headlights are exactly the same on the base and type S
keyword is stock, there are aftermakret versions out there that might look different.
_________________________
If they're OEM lights then it's the same.....the only thing that might be different is that the Canadian headlight is a bit different than the US, where the US has a clear lens cover for the turn-signal but Canadians don't.
:iamwiths:
And I'm not 100% sure but I think there was a recall on the headlights without the orange reflector on the outer corner. Due to the design of the lights with clear corner lenses, the sides of the RSX are supposely left vunerable to "not being seen." Unless of course you get the sidemarkers :D
Elite
:iamwiths:
the stupid fucking turn signal should have been housed inside the reflector to begin with or our cars should have had TSX mirror mounted turn signals. i hate how honda took cut costs with the RSX.
Sure don't...
thats what happens when you buy the bottom model
Discussion Starter · #15 ·
So Will Anyhting Be Noticeable If I Have One Type S Headlight And 1 Base Rsx Headlight?
Please Let Me Know
Thanks
^ no....no difference at all
rsx headlights are the same regardless of model (doesn't matter if it's base or type-s)
the only thing that matters is the year range. 02-04 headlights are the same, and 05-06 headlights are the same
so if you have an 05-06 headlight, you'll just need to find another 05-06 headlight
Please Let Me Know
Thanks
Unless you put a type S badge on the lights...no
1 - 20 of 20 Posts
