1 - 20 of 90 Posts
DSM DC5
I recently installed a set of 05-06 leather seats in my 2002. I assumed they would be a direct swap, plug and play. After driving around with the SRS light on for about a month I decided to reset the SRS light but had no luck, it kept coming on. I did some research online and found a couple things need to be done in order for the seats to be compatible. Your SRS light WILL be on and will STAY on if youdo not swap these parts. Here is my HOW TO for those doing the swap.
PART I - OPDS UNIT
1. Remove Passenger seat with the 4 14mm bolts. Unplug all connectors underneath.
2. Unzip the seat cover on the passenger side.
3. Pull back the seat cover on the side to access the OPDS Unit Cover.
4. Remove Cover by unsnapping it and unplug connecters.
5. Unscrew the two phillips screws securing the unit and remove the OPDS Unit.
6. Replace the 05-06 OPDS Unit with your 02-04 Unit. Install screws and connectors. Zip your seat cover.
PART II - SEATBELT AUTO TENSIONER
1. Remove the 14mm bolt from the seatbelt Autotensioner.
2. Unplug connectors under seat and remove unit.
3. After it has been removed, install your 02-04 unit on the 05-06 seat.
PART III - RESETTING YOUR SRS LIGHT
1. Jump your SRS Plug with a wire or paperclip. Yellow plug on fusebox.
2. Turn key to II, SRS Light will disappear.
3. Remove Wire, SRS Light Reappears, Plug Wire back in. Light Will disappear.
4. When SRS Light blinks twice, you are done.
5. Turn key to position 0, plug in SRS plug.
Whatever car you are installing seats in, you will need the original OPDS and Seatbelt Tensioner. Good luck, hope this helps. So, before you get all excited and sell your old seats, make sure you take out the parts needed.
Completed Swap (Ignore my Accord All-season floor mats!)
You dont need to swap out the buckles, only the OPDS sensor..
DSM DC5
Discussion Starter #12
The price included shipping from Florida to Washington State. They were new, only 10k miles on them and a 10/10 condition.
I was willing to pay the amount because they are hard to come by. I suppose I could go to a wrecking yard but who knows what they want and the condition of the seats, airbags still intact etc....
I just went out to the wrecking yard today and they only had 2 05's. Both had no seats.
UnDr PrShR
Nice i just literally took out my clothes and replaced them with leather.........and the SRS light is on so i searched and ..............wooohoooo!! a DIY :thumbsup:
DSM DC5
Discussion Starter #18
I checked part numbers on the Auto-Tensioners, they are different 04 to 05. I just swapped them out. I figured I might as well while the seats were out, just to make sure.
I guess someone could try swapping only the OPDS to see if you still get an SRS light. Who knows, why not just put the 02 Auto Tensioner in.
The passenger seat is the only seat with the OPDS, hence the name Occupant Position Dectection System.
Member
I did this swap - learned the hard way that the pretensioners/buckles had to be swapped too.
I tried and tried to reset the SRS system after swapping only the OPDS......then I finally swapped the pretensioners and successfully reset the system and the light went away.
Wish I'd known before I bolted the seats down.....
1 - 20 of 90 Posts
