1 - 3 of 3 Posts
Goodness...Just finished up replacing the waterpump for maintenance (190k miles) and man....This thing is a pain to do in the car.
Victory has never felt so good to finally get this bad boy out :firemad:
Had to remove a ton of things to get this bad boy out. There is ONE bolt on the waterpump that seems to be easiest to remove/loosen if you unbolt the Alternator to move it aside.
I wish I took a picture of that one bolt. But if you unbolt the alternator to move it aside, (you don't have to unplug the wires) you can slide in a combination wrench to break it loose.
Here's some picsss
Old on left vs new
This is the kind of thing left alone until failure, usually you get a warning of it dying through the week hole. If you think that's bad here's a pic of my Tacoma fixing a timing chain cover leak
Sent from my Pixel 2 XL using Tapatalk
Oof man, looks like a lot of stuff that needed to be taken out also :X
1 - 3 of 3 Posts
