1 - 11 of 11 Posts
08-09 accord CP pulley bigger than 03-07.. cheap boost
the 08-09 accord crank pulley is bigger than the 03-07 accord/tsx/crv/elem.
part #13810-R40-A01 $41.33 at hondapartsdeals.com
The circumference of the 08-09 accord crank pulley is 20"
The circumference of the 03-07 accord crank pulley is 181/2"
notching of the chain cover case is need to clear the pulley from rubbing same key and crank bolt are used.
It is inevitable
interesting find... could you measure the circumference of the inside/ribbed area? the outer part may be larger for added weight for additional dampening while the inside portion could still be the same. either way :thumbsup: for being on the lookout for new options.
2
Guest
Nice find. Does that CP have the elastomeric coupler like the other smaller units? That skeletonized design is why I ask.
Discussion Starter #5
well that would put the ribbed area about 1/4 inch deep.. will measure so that you can get circumference vs the 03-07. will wrap wire around and post up measurements.
Nice find. Does that CP have the elastomeric coupler like the other smaller units? That skeletonized design is why I ask..
yes it does have the rubberized(elastomeric).
It is inevitable
:thumbsup: i'm very interested in this so we can extrapolate potential boost difference.
It is inevitable
^ i can figure it up once we have the rib circumference/diameter... btw... you still have your old avy text from the old woman :laughing: wasn't sure if you had paid attention to that.
Alky fed rat.
THX, I have the Avy's turned off on.:eek:
1 - 11 of 11 Posts
