1 - 2 of 2 Posts
Hello,
I just replaced my clutch/flywheel. There was a 17mm bolt that I believe went through the starter motor that I stripped pretty bad. I was able to remove the bolt, but I want to replace it with a new one. I have searched through many part lists, I am having trouble locating this bolt.
I then looked at the bolt for the sub frame on the helms manual and parts catalog. I know the 4 subframe bolts are 17mm. But on the helms manual and parts catalog they are saying this bolt is (14 x 1.5mm).
Am I missing some knowledge here? 14 x 1.5mm to me is a 14mm bolt, but I know for sure the subframe bolt is 17mm
Please educate me in this bolt measurements.
Discussion Starter #2 (Edited)
Found part number : 95701-12085-08
Ok, I figured it out lol. The 14 in the picture I was referring to is the diameter of the bolt.
1 - 2 of 2 Posts
