1 - 20 of 36 Posts
cheeto dusted!
for my 30k thats coming up, are there things that i should need to do besides changing my oil and stuff? not sure how much of it that i can do myself or look out for but some tips would be great. :bow:
Livin the power of dreams
A 30K consists of oil and filter change, rotation, air filter change, unless recently done, and the cabin filters changed (air conditioning filters).
At least, that's what'd we'd do if you brought it in to the dealership.
Old S2000 R.I.P.
At toyota our 30k service includes; oil change, air filter change, balance and rotate the tires, pcv valve, transmission change, coolant change, and a throttle clean, not sure if acura's different. I know our colant is long life so should be fine to atleast 60k along with your trans fluid...
cheeto dusted!
Depends on how hard you drive your car. I've been changing my tranny fluid every oil change, I mean shiet it's an extra $10. It's been coming out clean everytime though so I might extend it to like every other oil change or every third one.
Cheap insurance.
Matt
rarely drive it rough, but might aswell do it, while i get my radiator flushed.. had to fill it with crap aftermarket stuff when it was running low.
cheeto dusted!
Discussion Starter · #10 ·
On the tranny flush, can you or should you switch to a synth. tranny fluid? I have synth. fluids in all my other fluids, I was just thinking that it mine help a little.
all depends on ur driving style or if you have knotchiness or grinding issues. if you track or drive hard often or have tranny issues, switching to Amsoil/penzoil syncromesh would be best considering everyone else here on the forums having good results with other than honda brand MTF. IMO, my rsx is my DD and i have no problem with grinding or knotchiness so im just sticking with honda MTF.
hey if im still under warranty, is the 30k maintenance free?
:crazy:
Are you asking if the service is free?
Well its not....you would have to pay.
And on a side note, its basically and oil change and tire rotation...
However every dealer is different so...
What kind of lubricants should I use for the door hinges and latches?
How do you inspect the brakes, tie rods, and other stuff needed...?
I don't have to change the tranny fluid at 30K, right?
Should I flush the radiator or just fill it back up?
Thanks in advance!
TriFlow is great.
Or a lithium grease. It's white.
You're just looking for leaks and such while inspecting tie rods and brakes.
No tranny flush at 30k. Only tire rotation, oil change and air filters. Both engine and cabin.
30,60, AND 90K SERVICES HERE AT THE HONDA DEALER I WORK AT INCLUDE:
OIL AND OIL FILTER CHANGE
INSPECT FRONT AND REAR BRAKES
ROTATE TIRES
INSPECT TIE RODS, STEERING GEARBOX AND BOOTS
INSPECT ALL SUSPENSION COMPONENTS
CHECK ALL FLUID LEVELS
INSPECT BRAKE HOSES AND LINES
INSPECT COOLING SYSTEM HOSES AND CONNECTIONS
INSPECT EXHAUST SYSTEM
INSPECT FUEL LINES
CHECK OPERATION OF ALL LIGHTS
REPLACE SPARK PLUGS
INSPECT AND ADJUST DRIVE BELTS
REPLACE TRANSMISSION FLUID
INSPECT AND REPLACE (AS REQUIRED) FUEL FILTER
ADJUST VALVES (AS REQUIRED)
REPLACE BRAKE FLUID
REPLACE AIR FILTER
REPLACE CABIN AIR FILTER
BY THE WAY IT WILL RUN YOU ABOUT $275.00
YOU REPLACE THE COOLANT AT 45K!
JUST A LITTLE FRIENDLY REMINDER FROM YOUR LOCAL ODONNELL HONDA SERVICE ADVISOR! LOL :thumbsup:
1 - 20 of 36 Posts
