1 - 20 of 84 Posts
which one is better for BASE????(auto)
which one you guys usein it??
the manual said. we can use 5w-30(witch is for Type-S)
2003 Acura RSX 5spd
I just use 5W-20. It says do not use 5W-30, unless you cannot get a hold of 5W-20.
doing stuff
If you have modified your car and you spin the engine higher than recommended (like most of us) use 5w-30 or even 0w-30. 20 weight will tend to sling off your internal parts more easily at high rpm.
Blue Beast
I use 0w-20
Push nice avatar of Kitsune
997 C4S
Might want to recheck the manual. It doesn't say you can use 5w-30 - it says to use 5w-20. With that said, Honda engineers > ClubRSX forum.
doing stuff
Are you operating your engine at stock spec? If you raise your rev limit and redline alot you should get an oil that won't sling off internals so easy. Remember that the original intent was economy.
Discussion Starter #16
no. i drive base auto. and the manual siad 5w-20 for BASE, but also can use 5w-30
and 5w-30 for Type-s, which is Economy feul.
doing stuff
kmkze04 said:
I use 0w-20
Thanks bro... and rep for your bling heh.... where you get the blue gauge conversion? :thumbsup:
Blue Beast
Haha thanks. Ludatic on this board did the guage conversion for me. Great guy.
1 - 20 of 84 Posts
