1 - 15 of 15 Posts
All motor Pro
Im a regular mechanic. In other words I work on peoples projects locally every weekend. I actually just put a brand new SOHC Vtec into an Ef hatch :] funn .. Anyway, I found my compression test and was suprised to find the results
1 - 230
2 - 230
3 - 230
4 - 230
Even numbers across the board 3 times in a row.. 95k miles and still kickin it, gotta love the k :giggitygiggity:
Damn, and when I did a compression test on my 2003 Type-S with 40,000 miles on her I got:
125
120
125
130
But the car runs fine....makes me think I might have done something wrong.
Sounds to me like you didnt disable your fuel pump. I Just pulled the ECU fuse.
What? I wasn't aware that you had to disable the fuel pump and/or pull the fuse to the computer when doing a compression test. I never heard this from anyone else when I was asking about the test.
Why would not disabling my fuel pump or pulling the ecu fuse cause my numbers to be so low?
All motor Pro
Discussion Starter · #15 ·
take care of ur engine and ye shall reap the rewards.
exactly.. The only reason I can think that I have such perfect compression is I baby the motor. It never gets ran cold. Its always wamred up to full operating temp before its driven. 75% of ring wear is done before the rings get a chance to fully expand.
and the 2500 mile old changes.
:thumbsup: for taking care of k20's
1 - 15 of 15 Posts
