1 - 9 of 9 Posts
Hey, so im hoping you guys can help me out. I drove my rsx-s from norcal to socal. On the way there i started noticing a noise every time i pushed the clutch in to shift. Usually on lower gears 1-3. And sometimes i hear it when im cruising. Its like the sound of a spinning disc in your comp once it stops spinning. Just a scratchy noise. Any ideas? THANKS!
might be similar to this guys problem.
http://forums.clubrsx.com/showthread.php?t=242762
I'll prob go get it checked out if anything but some info from you guys would help! thanks again.
Dood
Is there any squeaking or just scratching?
its just like the TS said, its like a sound of a disc in a comp spining when it stops when im shifting in lower gears 1-3 is usually when i hear it..
Discussion Starter #9
alright so i figured out where the sounds coming from. its from my manifold. do you guys think its something loose? or maybe something got into it?
1 - 9 of 9 Posts
