1 - 20 of 374 Posts
THERE ARE 5 BUILDS ON THIS 1 PAGE CONTINUE SCROLLING DOWN IF INTERESTED IN VIEWING
Well guys I have went a long journey since the day I bought this RSX-S (See pictures Below)
Ive done many different builds in the same RSX Chassis,
THIS THREAD IS NOW pretty DRY. Thank Photobucket for trying to make me pay for 3rd Party Sharing; Sorry Guys.
1) Originally All Motor
2)Turbo (Blown UP)
3) All Motor K24/K20 (Missing LMA Springs)
4) Stock All Motor Build K20Z3
5) K24/K20 All Motor (My Port) 290/205 Issues exhaust valve guide damaged.
5) K24/K20 All Motor 163 Pro 4Piston Port 310/206 Would be more if increasing VTC. (Current Setup)
6) K24/20 All Motor 156V2 4Piston Port 345/226 Increased VTC to 30, as well as decreased head gasket width.
Track Passes Links Below.
12.0 1/4 Pass: In Car pass https://www.youtube.com/watch?v=-WOupEo2e-w
Outside of Car Different Pass though at 12.0 Again: https://www.youtube.com/watch?v=yGBwDt12d1s
12.1 1/4 Pass:Inside of Car pass https://www.youtube.com/watch?v=4IpRho2U0P8
Outside of Car Pass: https://www.youtube.com/watch?v=F9ekzogG4Ec
12.4 In Car 1/4 Pass: https://www.youtube.com/watch?v=rDTfBqVuxPs
Ouside Car Pass: https://www.youtube.com/watch?v=pXhhIBeIFvs
12.5 Run -- https://youtu.be/A-34OuN9EsQ
12.7 Run -- https://www.youtube.com/watch?v=Jh0lE-NBsAc
12.8 First Ever Pass -- https://www.youtube.com/watch?v=lm77dIKY6SM[/COLOR][/SIZE]
For some background on the car:
Car was purchased as it sits below 51K miles on the Cluster.
Car was COMPLETELY RICE clearly.
The car was my daily for a while until I became more interested in Tracking the car.
Everything done to the car besides (Paint, Transmission FD Install) Were done by ME!
Of course im not talking about the RICE paintjob Below seen. :rotfl:
Anyways All posts/pictures are moved to first page for it to easier be viewed please take a gander and dont be a stranger to comment.
Thanks for taking the time to view my Build CRSX! :ruiz:
014_zps88dcf9a9 by Daniel Perry, on Flickr
012_zps528c1918 by Daniel Perry, on Flickr
013_zps30f78345 by Daniel Perry, on Flickr
First Day I Bought her. 50K miles. Atrocious bumper. Euro Crap Taillights. Stock Oem Wing.
Build 2
Mod List:
Greddy T517Z Turbo Kit
AEM Fuel Rail
Walboro 255 Fuel Pump
Some Janky ass Supra Injectors
Greddy Intercooler Piping
Open Downpipe
Internal Wastegate
HKS Mushroom Filter
OMNI 4 Bar Map Sensor
Golden Eagle Vaccuum Block
Electronic Boost Controller
Kpro
This build was a bit rushed as at the time the car was my daily. It was short lived also, on my drive home from the dyno the car jumped time and a piston hit a valve and basically destroyed the motor. The motor blew up due to the timing chain tensioner failing and didn't have anything to do with the tune.
The Pictures have been removed due to Photobucket being lame and trying to charge people for sharing photos from their site.
Boost DYNOVID
https://www.youtube.com/watch?v=PZ1TQ5o-iWI
ALL MOTOR First K24 DYNOVID
https://www.youtube.com/watch?v=HR35FqLxZJ0
ALL UPDATED PICTURES WILL BE KEPT ON FIRST PAGE FOR KEEPING BUILD UPDATES EASY TO FIND. THANKS FOR VIEWING!
Post BLown up Turbo Stock K20, K24/K20.
BE18DF3B-21B7-4C6E-B148-8A3902B21C33_zps9x1relsi by Daniel Perry, on Flickr
Build 3 Mod List:
4Piston Modified K20a2 Oil Pump
K24a4 Bottom End
K20a2 Head (Stock Port)
Prayoonto Stage 4 NA cams
CP 12.5.1 Pistons
RC 750cc Injectors
Eagle Rods
Cometic Head Gasket
90mm Ktuned Throttle Body
Prayoonto Centerfeed Intake Manifold 90mm Inlet
AEM Fuel Rail
OEM fuel lines
4" Intake Pipe
1/2 Size Alpha Skunk 2 Radiator
Custom ASP Header
Full 3" Custom Exhaust, HKS Hi-Power Tip
B55A8D4B-7C13-4C6F-B1EA-2BC1F6EC7FFB_zpszwcpxuzm by Daniel Perry, on Flickr
Shortly after the tune the car seemed to not be running so well. I originally noticed that in the head of the motor, it was very loud/chattery. So I decided to start pulling the Valve Cover off and do some investigating... Little did I find that I had forgot to put the LMA springs into the head when installing the cams. I didn't put this out there very much tbh because I was pretty embarrassed about it for a while... But you live and you learn. I 100% Built this engine all myself and I am proud of that. That is why the build is basically going to be put on hold until I can get it how I want.
Post K24/K20 Went and picked up a K20Z3 that was tore down did a full OEM rebuild and went and had it dynotuned in the meantime since I had some other things going on.
Build 4
Mod List......
Stock K20Z3 Bottom End
K20Z3 Head Mild Port/Smoothed
RBC Port Matched to head
Arp Head Studs
K20Z1 Cams from 05-06 RSX
Kpro
Stock Injectors
Stock TB
Injen Cold Air Intake
Custom ASP Header
Full 3" Exhaust, HKS Hi-Power Tip
I Made sure to put the LMA springs in this time!!!! :)
Also picked up a Aspec Lip Kit, and a Type R wing and had them paint matched to the car. And I think the result turned out great!
4B96AB93-6146-402B-8D71-0FD5AD01AED3_zpsy220wtpb by Daniel Perry, on Flickr
B73F4121-1CB1-4A98-AF89-684162863305_zpsxgjqn1xo by Daniel Perry, on Flickr
Also here's a video my buddy made of my car and a modified 240 (Silvia setup)
https://youtu.be/0YaqyxWbxyg
561E49AF-2A02-4C72-9595-B134EB0B6122_zpsbqrc1jzn by Daniel Perry, on Flickr
Dyno sheet
213hp 154tq on a mustang dyno on a 97 degree day in the dyno room.
End of Stock Motor Rebuild as I sold the motor and now am revamping the car with the K24/K20 Setup. Continue Below to next post for Info on that Setup.
Discussion Starter #7 (Edited)
BUILD 5 (CURRENT SETUP)
MOD LIST ONCE AGAIN:
K24a4 Bottom End
K20a2 Head Smoothed/Mild Port - Upgraded
Drag Cartel Stage 4.5 NA cams - Upgraded
ID 1000 Injectors - Upgraded
CP 12.5.1 Pistons
Eagle Rods
.042" Cometic 87.5mm Head Gasket
Prayoonto Centerfeed Intake Manifold (Runners Ported/Polished, Port matched to head) - Upgraded
Custom 4" Intake Pipe
Karcepts PS/AC Delete Kit - Upgraded
Ktuned Swivel Kneck Thermostat - Upgraded
Ktuned Fuel Rail - Upgraded
Ktuned Heater Outlet Plug - Upgraded
Ktuned Thermostat Housing Plug - Upgraded
Ktuned Upper Housing - Upgraded
Ktuned 6an Fuel lines E85 Compatible - Upgraded
Ktuned Race Spec Shifter Cables - Upgraded
DriveShaft Shop Stage 2.9 Axles - Upgraded
FD in Trans Changed to 4.76 - Upgraded
Custom ASP Header
Trying to spread the builds apart from each other so its easier to follow them...
K24/K20 AGAIN Guys Here weeeee GOOOO!
Again after some more modification currently that the car is undergoing, car will be more of a Autocross/Road Racing/Strip Car. Pretty well balaced is my goal, But mostly to have fun with the car.. I wasnt it to be competitive and if possible try to win some money back that I have put into the car.
Cleaning up the engine bay and running My engine harness through the front impact bar, along with my fuse box under the driverside headlight
Removed all Sound Deadening Glue from the Rear
0D449364-12B4-4F1B-9320-AB0E2396E0F9_zpslih0svwn by Daniel Perry, on Flickr
2A94F982-AE4A-4B19-982A-07A5FE8E9D4A_zps40bsde7k by Daniel Perry, on Flickr
All Deadening Completely Removed (22.5lbs)
EVEN MORE PROGRESS
Ktuned Shifter box going back in along with new Ktuned RaceSpec Shifter Cables.
Follow to Next Post For Further Updates!
Discussion Starter #8 (Edited)
Build 5 Continuing
Alright Continuing! Motor is Assembled now, am going to be porting/polishing the intake manifold runners so just more of a test fit at this point but still looks pretty good IMO.
Untitled by Daniel Perry, on Flickr
Porting, Port Matching and Polishing my Intake Manifold is now Finished.
Velocity Stack came in the Mail today! 4x10 For some super serial power.
At Innovative MotorWorks on DYNO!
DYNO VIDEO
https://youtu.be/KhkJqHxWbdA
Couple clips of the car running!
https://www.youtube.com/watch?v=dAOdEsOFYe0
https://www.youtube.com/watch?v=JzTc0liw3z4
Low And $low
i'll check back once "nice"
Low And $low
how did this win best acura in show. :deadhorse
I <3 My RiceRocket
Ugh I keep checking each update but still rice... Im full already
Discussion Starter #14 (Edited)
K24/K20 Quest for 325
65F3D6AB-7EC4-4EA2-8163-57FC00B82943_zpspiszozjo by Daniel Perry, on Flickr
Best all around Tune line I went with, Strong midrange and a good TQ curve 308whp/203wtq
https://www.youtube.com/watch?v=9NJCouRZ8Ro
309/206 Pull
https://www.youtube.com/watch?v=NeHqHShKTsk
Behind Car pull
https://www.youtube.com/watch?v=W8T2Df3qk6c
In front of car pull
So I am running into clutch lockout at high RPMs due to my pressure plate being too heavy. Wouldve liked to got a new clutch for it but I honestly didn't fell like tearing it out of the car and doing it at this time. So I just decided to set Rev limiter at 8500. The car was able to run a 12.7 at a poorly maintained track with some granny shifting. The first ever run it ran a 12.8 on a well maintained track so I know it with a poor launch. So I know the car as it sits is capable of low 12s. I would reallllly like to see 11s though.
12.5 3 Times in a row shifting only at 8k
Been doing some other things in the spare time lately to clean up the engine bay.
Discussion Starter #15 (Edited)
Build 6 Changes:
K24a4 Bottom End
4Piston 156v2 Ported Head (Different Port)
ID 1700 Injectors - Upgraded
CP 12.5.1 Pistons
Eagle Rods
OEM 87mm Head Gasket - Upgraded (Compression Increased)
1/2 Size Koyo Radiator - Upgraded
Mittsimoto Fan Shroud - Upgraged
Ktuned Fuel Rail
Fuelab Inline Fuel Filter - Upgraded
Walboro 450 Fuel Pump - Upgraded
Action Clutch Twin Disc
OEM EM2 Clutch Master Cylinder - Upgraded
OEM Slave Cylinder Replaced
Car was Tuned on both E85 and on M5.
E85 Car made 321/211
M5 Car made 345/226
New Radiator Setup
Crusining Into the Eibach Meet VIP Section.
Motor Madness
Looking forward to getting this one down the track and seeing how it does compared to the last setup.
because "Type R" badges are a bit of a stretch. We all know Honda owns Acura so its usually ok to put "H" emblems. But its your car so F what anybody has to say lol
1 - 20 of 374 Posts
