FIXED SEE BELOW
Alright fellow RSX enthusiasts, starting another AC thread! Before I'm crucified, I will say I have thoroughly searched through all AC related info on the site but still have a few questions.
So my issue: no AC at all from my new to me 02 type S. I thought it may be low on r134a so I recharged it at first. No dice. It was on the low side, but once it was filled nothing changed. After a few days it seems to be holding pressure well so I don't suspect any links.
So after thorough perusing of the threads, I first checked the AC code with the diagnostic test. No codes appeared after initialization. This brings me to my first question. There was someone who had a bad Climate Control unit. Is this a common thing or nah? It works fine in the cold, aka modulating heat as it should, and the AC/recirc/defrost lights come on just fine. However, there are times where I can't turn off recirc when the AC is switched on. Is this normal or is this any indication of control unit failure?
That aside, my next check was on the compressor. It *looks* like it's running when I peek down into the bay. I can't fully tell. It also does seem to be drawing load in that the rpm's and engine noise changed when the AC button is pressed. The passenger side AC fan looks to be running just fine as well (another common potential issue it seems).
All together it seems like all signs point towards a 16 year old compressor having bought the dust. I've already purchased a new compressor kit with the unit/oil/dryer/seals and whatnot plus new r124a refrigerant as well as having rented a vacuum to evacuate the system prior to recharging it with new refrigerant.
Anything else I could check prior to digging in?
In regards to the compressor swap, I noticed it's common to remove the radiator. Is this necessary? I ask because I replaced the rad less than 500 miles ago and am remiss to drain and refill with new coolant....AGAIN. PDF manual says to go in from the top; I may still do this and move the alternator since I *really* don't want to put new coolant in. Thoughts?
Also any other tips or tricks that may be helpful for swapping the compressor?
Let me know, thanks guys!
