1 - 5 of 5 Posts
Premium Member
Get one of the highest quality clutch kits at insane pricing.
Action Clutch OEM Replacement Clutch with OE Flywheel
Part Number: ACR-0489-OE / AC102-OEHD
OE Replacement Clutch System
  • Single diaphragm OE pressure plate
  • Reinforced organic sprung disc
  • Engineered for stock replacement applications.
Includes:
  • Pressure Plate
  • Clutch Disc
  • Throwout Bearing
  • Alignment Tool
  • Pilot Bearing
Action Clutch Stage 1 Clutch with OE Flywheel
Part Number: ACR-0489 / AC102-OEHD
Stage 1 Reinforced Organic Street System
  • Single diaphragm heavy duty pressure plate
  • 25% increase in pedal pressure
  • 50% increase in holding capacity
  • Slight increase in pedal pressure, smooth/linear engagement, and an extended wear life.
  • Engineered for naturally aspirated vehicles with bolt-ons who encounter heavy-duty street use.
Includes:
  • Pressure Plate
  • Clutch Disc
  • Throwout Bearing
  • Alignment Tool
  • Pilot Bearing
Action Clutch Stage 2 Clutch with OE Flywheel
Part Number: ACR-0490 / AC102-OEHD
Stage 2 Single Diaphragm N/A Kevlar System
  • Kevlar sprung disc
  • 50% increase in pedal pressure
  • 70% increase in holding capacity
  • Features a slight increase in pedal pressure, smooth/linear engagement, high resistance to heat, and the longest wear life of any clutch in our lineup.
  • Engineered for high horsepower naturally aspirated vehicles who encounter heavy-duty street use and weekend racing.
Includes:
  • Pressure Plate
  • Clutch Disc
  • Throwout Bearing
  • Alignment Tool
  • Pilot Bearing
Action Clutch Stage 3 Clutch with OE Flywheel
Part Number: ACR-0491 / AC102-OEHD
Stage 3 Dual Diaphragm F/I Metallic System
  • Dual diaphragm heavy duty pressure plate
  • Metallic sprung disc
  • 110% increase in holding capacity
  • Features a substantial increase in pedal pressure, smooth/linear engagement, high resistance to heat, and the longest wear life of any clutch in our lineup.
  • Engineered for moderate horsepower forced induction vehicles who encounter heavy-duty street use and weekend racing.
Includes:
  • 15LB Flywheel
  • Pressure Plate
  • Clutch Disc
  • Throwout Bearing
  • Alignment Tool
  • Pilot Bearing
Action Clutch Stage 4 Clutch with OE Flywheel
Part Number: ACR-0492 / AC102-OEHD
Stage 4 Single Diaphragm Metallic Solid System
  • Metallic Solid 6 puck style disc
  • 170% increase in holding capacity
  • Aggressive engagement, rapid heat dissipation, and outstanding holding capacity.
  • Engineered for high horsepower vehicles that encounter heavy-duty street use and frequent drag/road/drift racing.
Includes:
  • 15LB Flywheel
  • Pressure Plate
  • Clutch Disc
  • Throwout Bearing
  • Alignment Tool
  • Pilot Bearing
Premium Member
Discussion Starter #4
Includes:
  • Pressure Plate
  • Clutch Disc
  • Throwout Bearing
  • Alignment Tool
  • Pilot Bearing
Includes:
  • Pressure Plate
  • Clutch Disc
  • Throwout Bearing
  • Alignment Tool
  • Pilot Bearing
Includes:
  • Pressure Plate
  • Clutch Disc
  • Throwout Bearing
  • Alignment Tool
  • Pilot Bearing
Includes:
  • 15LB Flywheel
  • Pressure Plate
  • Clutch Disc
  • Throwout Bearing
  • Alignment Tool
  • Pilot Bearing
Includes:
  • 15LB Flywheel
  • Pressure Plate
  • Clutch Disc
  • Throwout Bearing
  • Alignment Tool
  • Pilot Bearing
1 - 5 of 5 Posts
