1 - 14 of 14 Posts
as title says... wondering my options are for a rear sway bar that is adjustable... i know there is progress 24mm and whiteline 24mm... anything else? also do these big sways usually fit ok with 3" exhausts?
GT30R > Traction
Hotchkis 27mm, and I don't know if it will fit with a 3 unless it's custom.
Late Apexer
Any bar can be adjustable if you've got access to a welder...
Low Flying Whore Ron
The Comptech adjustable will fit with the 3" KTeller
THe comptech adjusts by having for or five different spots on the outer portion of the bar where a small bolt connects it to the inner portion of the bay, while they are fitted together via a tongue and groove at only one end. By changing the position of the bolt, you change how much flex it has and it comes with a lower bar to renforce it too. It uses stock end links and that does not change. The holes are not adjustable.
However, Comptech has stopped making them. Too bad as I had two of them on twp RSX's that I owned. I set mine on next to stiffest position, and got nuetral if not a bit of oversteer...get one if you can find it.
Engineering
nope but i am
Engineering
you got PM
1 - 14 of 14 Posts
