1 - 11 of 11 Posts
I got an aftermarket head unit all the wiring is done right and I did the amp bypass and my head unit works sometimes when I turn on my headlights I'm not sure why?
[Insert Title]
Feels like some wires were crossed and grounding to one another which would explain why the device would only work if the headlamp is turned on which power is then being sent.
Doesn't Give A F*ck
How did you connect the wires together?
Twist and electrical tape? ( I hope not)
Discussion Starter #6
I did the wires so I know they are done right I have wiring diagrams from pro on demand I used butt connectors to wire them in. And I don't see anything involving headlight in the radio diagram
Doesn't Give A F*ck
Wanna take pics of the wiring?
Where did you bolt down for the ground?
Doesn't Give A F*ck
post up your wire work when you have a chance. like i said before, double check your wiring, everyone makes mistakes from time to time
1 - 11 of 11 Posts
