Sorry, posted this after your addition of the above post.
Looks like your lean cut problems are in the 40 degree high cam fuel table, columns 8 and 9, from 4500 to 6500 rpm. You are running as high as 14.86 a/f when you should be around 13.2. If you look at the lambda overlay for the 40 degree high fuel table, it will show you where you need to add fuel, and about how much.
If it were me, I would about 6 % from 3000 to 5500, and 10 to 12% from 5575 to 6500 in columns 8 and 9 and see if the lean cut goes away. You will be a little rich but you can tune that down after solving the lean cut. You may then have to work on the 30 degree high cam, as you don't really get there because of the lean cut.
This datalog shows 18 knocks but are from before you started recording. would need to see a datalog where the knocks are recorded to help with that.
