Looking to sell this set for $100 + shipping. Comes with everything in the picture. Local pickup is available in Downtown Los Angeles (weekdays) and Orange County (weekends).
I am fairly certain that the tweeters that come with this set are rebadged Vifa tweeters.
Disclosure:
- In one of the woofers, the paper cone has a very slight wrinkle in it. Doesn't affect performance or sound.
- There is some black glue on the sides of the tweeter as it was mounted to the bottom of the factory tweeter grill. It is purely cosmetic and doesn't affect performance.
Disclosure:
- 6-1/2" 2-Way Component System
- Custom Cast Aluminum Frame
- Airflow Optimized Dual-Flare Pole Vent
- Integrated Spider Landing & Heat Transfer Plate
- Low Resonance Multi-Roll Surround
- Wood Fiber Cone
- Phase-Integrated Dustcap
- 1.1" Soft Dome Tweeter
- Ultra High Quality 2-way Crossover
- On/Off Axis Compensation
- Bi-Wire Input and Selectable Tweeter Attenuation
- 4-Layer Copper Clad Aluminum Wire on Glass Fiber Bobbin
- Braided Low-DCR Tinsel Leads
- FEA Optimized Motor Structure with CRC/T-Drive Geometry
- Gold Plated Terminals
- High Grade Strontium Ferrite Magnet
- High Quality Synthetic Black Spider
- Integrated spider Landing & Vented Heat Transfer Plate
- Non-Resonant Suspension Coupling with Reinforced Edge
- Single Voice Coil Design
- External Crossovers Included
- Speaker Specifications
- Speaker Size 6-1/2"
- Design 2-way Component System
- Peak Power Handling 300 watts
- RMS Power Handling 75 watts
- Sensitivity 87 dB
- Frequency Response 35 - 60000 Hz
- Impedance (per voice coil) 4 ohms
- Top Mount Depth 2.8"
- Bottom-mount depth N/A
- Cutout Dimensions 5.2"
