1 - 1 of 1 Posts
Still learning and still fixing issues with a previously installed turbo kit (Peakboost)
The current issue i may/may not be having is that i get a flutter on low rpms through most gears but not when the rpms are let off higher i dont seem to get the same flutter. Both my wastegate (44mm) and BOV are Tial (unsure of spring ratings inside), connected to a distro block for vacuum, newer-ish Garrett To4Z compressor, 14.8 PSI boost on the high end. Point me in the right direction if you dont mind, i dont drive it all that much untill im sure its properly functioning ¯\(ツ)
Only video of car turbo'd i have at the minute
1 - 1 of 1 Posts
