1 - 4 of 4 Posts
Hi guys, so I got a error code with my secondary O2 sensor. Does it matter if I get a universal O2 sensor from Brosch or an OEM type(Denso or NGK) found on clubrsx.
On another note. How can you tell if an O2 sensor is short?
I would highly suggest getting an O2 sensor that is made for your car. A universal one you will have to probably wire up to make it work, and since an O2 sensor gives an electronic signal the resistance in the wiring is fairly important.
SupA FlY......
get a ohm meter and measure the resistance of the 2 black wires(primary) or the 2 white wires (secondary)
1 - 4 of 4 Posts
