Or at least from what I hear. Recently it rained pretty hard and I own a CAI. Well I must of slightly submerged it(don't know how because I only hold a slight drop) either way I had WOT in 1st and in suddenly bogged down.... so I was like 'uh...ok' then I tried it again and yet another slight bog. So then it started to idle sort of funny . With al this in mind I cruised to the nearest gas station conservatively.
At the station it started to run fine again, startled, I continue to drive to a friends house to get out of the rain. Well later on I start it, it starts fine like usual and no odd idle. So I continue to go on the highway and do a slight 2nd gear pull to make sure it runs through fine and well .....No VTEC.
I turn the car off and then after a few hours time I run through it again... No VTEC. Yeah so I stumbled by the situation.
Cliff Notes:
1. Bogg and odd idling at 1st. due to Im guessing inhalation of water
2. Now starts fine and idles fine. NO CEL's
3. Still no VTEC.
So likely in the morning I will look at the CAI and make sure there are no pockets of water in the filter and what not. After I will run through 2nd to see if it engages... if not Well seems I will be pulling the valve cove off for a quick looky.
So can anyone help me with tips and what not?
Thanks.
Cliff Notes:
3. Still no VTEC.
Thanks.
