Interesting. So do you base your rpm capabilities only on Rod/stroke ratio? What about Feet per Second/minute? (Or more specific with tensile strength and G force calculations) etc...edo said:1.85:1 rod stroke ratio....
10,500rpm capable
We'll see what the turbo maxes out at, as well as the other components. To make power that high, we'd need to run an open 4"+ downpipe or something with a HUGE GT45R turbo.
-Ron
Wow... That will surpass the R/S Ratio of the B16B!!! That engine will rev so smooth!!!edo said:1.85:1 rod stroke ratio....
10,500rpm capable
-Ron
What will be displacement be with that combo ron? Do you know for the formula for calculating it off hand? I dont want to have to ask peeps all the time.edo said:Honda. Stock 86mm RSX-S crank with some massaging. K24 block with 6.250" long rods.
-Ron
