Status
Not open for further replies.
1 - 20 of 2007 Posts
GT30R > Traction
All the other forums have one, so hopefully this will help with the stupid do I need a camber kit threads.....
Please read the FAQ in the sticky section
question. I'm dropped on tein ss-p's and I have ingalls camber kit. I went to get an alignment and my front tires are still getting worn out to the wires. I figure it was a shitty alignment but I want to know if it could be anything else. Also my steering wheel shacks vigirously
GT30R > Traction
lol here we go, what's up Rob
Slow in Fast out
Richard,
Your wheels are unbalanced, causing the steering wheel to shake. Now is the entire tire wearing or just the inside half? If the entire tire is wearing, you have a toe issue. If you have too much toe-out, the car is going to be unstable at high speeds and wander under the brakes. If you have too much toe-in, the car will be very "darty" under the brakes, entering corners, or over bumps.
Too much negative camber will burn the inside of the tires overtime.
Who did your alignment?
Richard,
some rinky dink shop did it. No it only wears on the inside right side the most. The middle wears but on the right side is where the wires start to expose
Slow in Fast out
Hmmm, when you power-on does the car wander left? (hands off the wheel) Sounds like uneven camber or it simply slipped.
yes it shakes alot now and when I let go of the steering wheel it just goes to the right
Slow in Fast out
mmm P-Tuning now does corner balancing, about time. Gotta get it done for next season.
Slow in Fast out
lol richard your alignment is all screwed up, just have it re-done.
Slow in Fast out
You should, hell I would. You'll like p-tuning.. they do really good work.
Seats yet?
Late Apexer
if the tire wear is only happening on one side of the car, then its not a toe issue.
Start looking for worn bushings, bad wheel bearings, worn dampers and the like.
i am currently riding on cut springs, low enough to ride da bump stops. the car is still too high
can i cut da shocks to make my car sit lower????????
Status
