Status
Not open for further replies.
81 - 100 of 1983 Posts
Gothic Hippie RSX tuner?
I'd start asking questions, but I guess I'll back to the beginning and read. But I'm sure I'll be back with questions. It's time to start my education in nitrous.
I heard you're moving to florida Pepsi?
Discussion Starter #82
yes sir, but try and keep this thread on topic, thanks :thumbsup:
You can get your basic single fogger installed for anywhere between $250 and $500, depending on where you go... For example where I live I have a shop that will do the install for $350CDN I know they're fully capable and would trust them to do a good job.. On the other hand I would be purchasing the kit from a company called Mopac that would want about 8hours of labour at 90$ an hour for the install, and they garantee their install... They are also a huge sponcer for our local track out here www.missionracewaypark.com , maybe even an owner Im not postive though.. Also one of the very few places that fill N20 in the lower mainland...
Sum it all up... the price ranges but you get what you pay for... The installs not that difficult but if your like me you like to get things done right so your 100% sure your not going to blow your motor or you fuck something up... That piece of mind is priceless!!! So its your call...
Also I would probably start with the 50 shot and work your way up, trust me you will eventually get your way up to 100 with out a doubt.. maybe even 125!!!
Adam
pepsi: in one of the thread u stated that NOS bottle openers wouldn't work on NX bottles without some modifications, what exactly would u have to modify? also does zex remote bottle openers work on NX bottles?
Discussion Starter #85
the nipple that comes with the nos one, won't fit in the nx bottle. also, it can't screw "in-line" with the nx bottle, because the threads are different.
because no line will constantly hold pressure i'm almost stuck with gettin a NOS bottle, or goin back to nx's opener :(
i don't see why you can find a line that will hold the pressure. have you thought of EVERYTHING? I think all it would take is a small, solid line. Don't limit yourself to just what the N2O companies supplies. I work with 10kPa H2 in my fuel cell, and there is no problem holding that kind of pressure in a solid line.
Discussion Starter #87
teflon is pourous to gas, i'm running a custom line right now, and it holds twice as long, but still leaks. Short of running a metal line, the stuff just slowly seeps out, and i've almost lost the urge to deal with it, ya know?
so you're saying you just don't want to deal with a solid metal line? Or, are you saying that wont work either?
I know what you mean though. If you give up on it now, I'm sure you'll get the urge to mess with it again sometime in the future.
Discussion Starter #89
i don't wanna deal with a solid line. If anyone has a spare 15 lb NOS bottle around, or has one, i'd love to see if the thing would fit, i just hate the nx opener, and i haven't sprayed in for-life, because it's such a pain :(
Discussion Starter #92
chris97hds said:
How safe is it for a stock engine?
with the right safety stuff, and run properly? i've heard of no malfunctions on the rsx, due to anything but user error.
Discussion Starter #94
RSXn Mo said:
does anyone have forged internals running nos? And do they have forged rods and pistions for the base rsx?
not that i know of. stock has handled 125 fine. anything more, and i'd wonder why you're spraying instead of boosting.
Discussion Starter #96
i think the stock bottom will hold it fine. the issues a few have gotten into was with head stuff, valves and such.
again, i don't reccomend spraying 125, and i don't recommend modding anything to spray 125 or more. if you want over 125, you should be goin a different route on a 2 liter engine.
cool thanks for the advice.
which kit would you recommend me getting then. I want to run a 50-75 shot.
and what other things would you recommend, ive been reading all the stickies, but im still not sure on what do get.
Or is there a kit on the market that has absolutely everything that I would need.
and how much am I looking at spending here to run a safe nitrous setup on my base.
and warm pepsi thanks for the help i really appreciate it.
Mo
Discussion Starter #98
Mo
most of us are running from 50-75. it's fairly potent, and it's fairly safe. It's a great compromise.''
The sticky has a lot of this info, and maybe more than i'll remember to say.
Nx + NOS are basically the same style kits.
The question to you, is do you want to run dry or wet? Wet is fine just as is (don't want hondata reflashes at all) and it'll take care of adding fuel + nitrous.
Dry basically requires the Hondata programmable computer ($1k if you don't have hondata yet) and it uses the stock injectors to add the extra fuel.
Some people have a preference, i've never used dry, and the overwhelming cost, and the lack of availability when i did my setup, make it not even an option.
For a basic kit, with the genx-2 upgrade, you're looking at around $1k. the upgrade comes with a bottle heater, blow down, purge, low fuel pressure sensor.
After that, if you want a remote opener, an rpm window switch, and at least a nitrous gauge to monitor your bottle pressure, you can tack on close to $500 easily. (plus a gauge needs a pod or a cup to mount it in).
this stuff adds up real quick. i estimate my system to cost around $1600.
I have a question on adjusting timing and fuel through using a resistor on your IAT sensor plug.
can you adjust it enough for a dry nitrous kit to run safely at a 55 shot on the a3
Discussion Starter #100
i'm gonna give that a solid "no".
if you do such a thing, it's constant. i'm not sure of the specifics, but i'm fairly sure you wouldn't even gain near enough fuel.
Status
