1 - 14 of 14 Posts
Discussion Starter #6
rasied up the redline from 8100 to 8600 wow what a difference!!! Couldnt get the antilag past 14psi today and bogging so we got to get it higher now so I don't have to slip the damn clutch soooo much.
The motor is running really strong almost track time!
Knock on the wood all the drivetrain junk is holing for now multiple drops in 1st I think PPG is up for the task!
Discussion Starter #8
Trans is a Ppg gear set with a mfactory LSD and the driveshaft off a diesel truck, rear end is 7 inch and the only thing that might is the axles or tcase :) not that bad I have a spare tcase and axles will be made from DSS. Thanks!!
Discussion Starter #10
AWD RSX Turbo doing work lol.... Name is Jasmin Buric... I am getting a go pro this weekend and doing some launches.... Should be fun!
Discussion Starter #11
Chriselmo hmu on FB tho the name is Jasmin Buric if you wanna know some intense details since there was soooooo much done to the car since the last update I would have to look into where I left off.....
nasty
1 - 14 of 14 Posts
