41 - 56 of 56 Posts
bum tumblr-er
Awesome integra, super clean! Love those wheels...
....Baywatch
Discussion Starter #46 (Edited)
Went to get tuned at Raceline this past week. I've been pretty quiet about my setup until now, but I guess it's time to say, the reason for the head rebuild was because I came across some Toda Spec B cams. Elton did an amazing job tuning the car. As soon as he drove the car on the lift he knew timing was off and adjusted it within a few minutes. The bottom end remained stock and has about 150k miles on it, and the rings aren't the best. But I managed to put down 170whp and 126tq on their dyno (dynojet). I was very impressed with the results but there's still more power to be made. The C.A.R.B. legal comptech header and apex-I N1 catback is holding me back. Going with a full 2.5" setup, and 3" cold air and then I'll see some good gains. Student budget FTL. Definitely looking forward to the retune. Pics from the dyno day and a small photoshoot I had below.
....Baywatch
Discussion Starter #53
Thread update
Engine:
-Skunk2 Intake Manifold
-Skunk2 Alpha 70mm Throttle Body
-AEM V2 Cold Air Intake
-Supertech Dual Valve Springs
-Supertech Titanium Retainers
-Supertech Flat Faced Valves
-Supertech Bronze Valve Guides
-Supertech Valve Stem Seals
-Toda Spec B Cams
-Buddyclub Cam Gears
-Gates Racing Timing Belt
-ARP Head Studs
-Comptech USA Header
-Apex-i N1 Cat-back
-AEM 320 Fuel Pump
-Marshall Fuel Pressure Gauge
-Password JDM Carbon Fiber Spark Plug Wire Cover
-Moddiction Burnt Titanium Hardware (Engine Bay)
-Downstar V1 Beauty Washer/ Bolts
-Buddy Club Oil Cap (Black)
-Spoon Resivoir Socks
Engine Management:
-Hondata S100 (Tuned by Elton @ Raceline USA)
Suspension:
-Skunk2 Pro S 2 Coilovers
-Password JDM 3 Point Front Strut Bar
-BWR Subframe Brace
-BWR LCA's
-Energy Suspension Sway Bar Bushings
-Bennen C-pillar Bar
Drivetrain:
-Clutch Masters FX200 Clutch
-Competition Clutch 12lb Flywheel
-Energy Suspension Shifter Bushings
-Honda OEM Manual Transmission Fluid
Exterior:
-Top1 Motorsports License Plate Tilt
-Top1 Front Splitter
-Bayson R USDM ITR Replica Front Lip
-Honda OEM ITR Spoiler
-Limited Edition Honda-Outfit Carbon Fiber Gurney Flap
-Honda OEM Mud Flaps
-Paint Matched Side Skirts
-Bi-Xenon Retrofitted Headlights (Infinity FX35 Projector)
-Clear Corners
-DDM 6000k D2S Bulbs
-DDM 35w Ballast
-DDM LED Switchbacks
-DDM LED Rear Licence Plate Lights
Interior:
-350mm Nardi Deep Corn Steering Wheel (Suede)
-NRG Steering Wheel Tilt
-Blox 490 Spherical Shift Knob (NeoChrome)
-Sony DSX 210X Head Unit
-Rockford Fosgate Speakers (6.5" Components front 6.5" 2-way rear)
-Polk DXi 10" Subwofer
-Hi-fonics Amps (1000watts and 400watts)
-Prosport Amber Gauges (Oil Pressure and Oil Temp)
-Custom Gauge Bezel
-LED Map and Dome lights
-DDM Wedge LED's (Gauge Cluster)
Wheels & Tires:
-Enkei RPF1 (16x7 +43)
-Federal 595 (205/45/16)
-Blox Extended Wheel Studs
-Project Kics 10mm Wheel Spacers (front & rear)
Brakes:
-Brembo Blank Rotors
-Hawk HPS Pads (front & rear)
....Baywatch
Discussion Starter #54
Been a while. New update.
Updated Mods List
Engine:
-Skunk2 intake manifold
-Skunk2 70mm throttle body
-Go-autoworks 3" cold air intake
-Supertech valvetrain
-Supertech flat faced valves
-Toda spec B cams
-Buddyclub cam gears
-Gates Racing timing belt
-ARP head studs
-Comptech USA header
-Custom 2.5" Vibrant exhaust
-AEM 320 fuel pump
-Marshall fuel pressure gauge
-Circuit hero spark plug wire cover
-Downstar V1 hardware
-JDM ITR oil cap
Engine Management:
-Hondata S100
Suspension:
-Password JDM 3 point front strut bar
-ASR Subframe brace
-ASR 24mm rear sway bar
-Function 7 LCA's
-Bennen C-pillar bar
Drivetrain:
-Clutchmasters FX2000
-Dimes shifter bushings
-K-tuned Pro Shifter
Exterior:
-Checkered Sportss license plate tilt
-Bayson R USDM ITR replica front lip
-Paint matched side skirts
-ITR spoiler
-Carbon fiber gurney flap
-Optional mud guards
-Bi-Xenon retrofitted headligts (Infinity FX35 projector)
-DDM 6000k D2S bulbs
-DDM 35w ballast
-Clear corners w/ LED switchbacks
Interior:
-Blox 490 spherical shift knob
-Kenwood DDX372BT Double Din
-Rockford Fosgate speakers (6.5" Components front 6.5" 2-way rear)
-Polk DXi 10" subwofer
-Hi fonics amps (1000watts and 400watts)
-Prosport amber gauges (Oil pressure and Oil temp)
-Custom gauge bezel
-USDM ITR gauge cluster
-ITR faux carbon climate control
-ITR faux carbon ashtray/lighter
-ITR faux carbon cup holder
-UKDM ITR serial badge
-350mm suede Nardi Torino (blue stitch)
-Custom retrofitted Evo 8 Recaro seats
Wheels & Tires:
-Rays Gram Lights 57DR Mag Blue (15x8 +35)
-Toyo R1R (225/45/15)
-Tredwear "Toyo Proxes" tire letters
Brakes:
-Brembo rotors
-Hawk HPS pads
Doesn't Give A F*ck
nice. how did the s2k do with the front end kissing the ground?
....Baywatch
Discussion Starter #56
I don't even remember lol think he got me on one, i got him on another haha
41 - 56 of 56 Posts
