1 - 10 of 10 Posts
Track Ready RSX-S
Hello all, so I recently put my rsx-s together when I first wired up the engine harness I messed up the TPS and MAP sensor which blew up my MAP sensor and is causing me lots of headaches. I have spark, fuel, good power and grounds. I want to mention I removed the ABS, P/S, A/C, SRS system and the rear speakers and subwoofer. Relocated my fusebox to the inside of my car and the battery as well. First problem I am having is when I go to start my car (crank it over), (foot off the clutch) my radio resets and continually try's to reset until I stop. I know its probably dropping below 12v so it resets but why if I am not actually drawing power to the starter? Also does it when I put my foot on the clutch. I am thinking it needs a better ground.( radio is the least of my worries though). Its aftermarket headunit. Anyways my main concern is my car wont start. I have noticed that the timing advance is probably no correcting itself like it should(looking at a nice scanner). I know the camshaft position sensor and crankshaft position sensor are both working good. Timing chain has not jumped I checked twice. I have a RRC crank-pulley, could this affect it? The motor is stock other than an exhaust and intake. Has around 175 for compression on all cylinders is that okay? Too low? Suppose to be 220,200,200, 220 I think. My last attempt will be a new ECU I am just concerned that if I purchase another one I might fry it again... Please help anyone! I have stock ECU now. Would Hondata be a safe alternative?
Track Ready RSX-S
Discussion Starter #2
Update, not the harmonic balancer. LOL I'm losing it! I have noticed the LTFT and STFT are not reading anything. Fuel is priming and entering the cylinders, not sure how fast though. Tried starter fluid many times. Still thinking it's the ECU. I'll be purchasing one on Monday from a junkyard to test it out under warranty. It was not my immobilizer and my fuel pump is priming and my green key light does not flash when first turned on. Reason ECU might have fried is due to the bad ground on first crank with MAP and TPS sensor reversed by accident. Hope this helps people. I'm a F*^$%^# HONDA PRO now! Oh and when I remove the ECU fuse it doesn't seem to turn over any different. Really wanted to bring it to all the car shows this weekend. :(
Track Ready RSX-S
Update, its not the ECU from what I can tell bought another ECU still doesn't run. Not really sure where to go from here. :(
Did you ever figure out what the problem is? Im experiencing something similar. My car used to crank but didnt start due to the fuel pump not getting power and turning on but now i fixed that the car doesnt even crank or click. I hooked up an obd2 reader to the car and its getting an error in trying to read or connect to the car. When i put the key to accessory mode, all the dash lights comes on but when i try to start it, everything shuts off and comes back on.
If your car ran, and now it doesn't and you did some wiring stuff, don't look at all the other stuff, focus on what you just did.
I've said this in other post's. It's called "LOOSING THE RABBIT". Now he's in a hole DEEP! Going back to where he started? As in where everything has gone to hell. Go back to that? Good luck...wheres fuc'n m>>>>>17 when we need him? Probably out with some hooker.
Try an ignition SWICH? Just a thought?:dontknow: But it's possible....
Track Ready RSX-S
Discussion Starter #9
Second update
Basically I gave up. I am redoing everything start to finish now the best way possible. However after many hours of trying to get my car to fire and tearing everything down. I noticed my main ground wire to my tranny was loose against the chassis. Would recommend checking all grounds again... needless to say I was too lazy to put it back together at that point to try and crank it over again.
Best of luck,
I'm getting this same problem any updates on yours?
1 - 10 of 10 Posts
