1 - 20 of 166 Posts
· Registered
they're a lot better than my auto rsx, i'll tell u that. i've driven both, and the si is much more responsive and powerful, especially in the upper rpms. shifter's nice too. never driven a base manual rsx tho
· Registered
if both cars were equally modded i would say it would always be close unless one driver really sucked! i think it could go either way!
D
· Registered
I think that the SI would win by a little bit because they have the different intake manifold like the S does and they also are a little lighter if im not mistaken. It would still be very close but I think stock vs stock the si would win by a little bit
· Registered
if driver was the same, I also say si would win...not by much though. Due to the fact they are lighter and their redline is higher (to my surprise). I think I read some where that it was around 7500. I don't quite remember. I didn't know about them having different IM either. Either way...it would be a hell of a race stock to stock.
· Registered
Stock for stock the Si will win by a small margin (Maybe half a car to a car). BUT, the base RSX is lighter than the Si. The Si has a few things that the base RSX doesn't. The Si has the same intake manifold as the Type S and it also has a 4.764 final drive (Same as Type R and TSX) that the base RSX does not have. The Si has the same redline as the base RSX...however with the Type S intake manifold it will continue to make power all the way to 7700 RPMs, so with a simple ECU reflash it will really wake up the car (kinda like it wakes up the Type S too).
In the really real world; stock to stock, it's a driver's race between the two ;)
· Registered
Discussion Starter · #8 ·
out of the poeple who have driven a civic SI or who own one, does the shifter up on the center counsel ever get annoying or tire your arm out, or is it just flat out better?
· Registered
good try I have a si. The car, not driver is quicker than a base rsx. Not slower. As far as the shifter goes i have my si and a 89 240sx. The shifter doesnt get tiring or anything. It would take someone about 30-45 minutes to fully get used to. I actually like it alot more than traditional placement. However if you drive a car with the traditional placement then get back into the si it feels like your reaching really far to get the shifter.
· Registered
I really like the dash mounted shifter. I drove a TSX and found it kind of annoying to have to reach down towards the floor to shift! Also, I put a K20A2 in my Si, so I have the best of both worlds - Si utility and style (yes, I like it) with Type S performance.
· VS. Godzilla
I never raced one to my surprise... Not much SI in my area. What 1/4 time do the SI run in stock form. I think the SI wins the race because of 15in wheels? given same engine but minor differences in stock form? So SI will win I guess... Someone did an analysis for Klutch b4. 5lbs to each wheel will lose .2secs, so that's about 1/2 car?? Why am I saying a SI is faster? Dunno... But who cares when my car don't look like a GTI... Hee...
· Registered
Do we really have to put in the whole k20a2? I didnt think so but im not sure. I thought we could just swap heads and itd be the same cause we have the same block correct or incorrect?
· Registered
Swapping heads will give you the "real" vtec system and all the rpm capability of the type-S but the K20A3 has less compression than the A2 so it will not be the same as swapping the complete motor. Frankly, swapping the complete motor is not difficult & probably easier than swapping heads. :driving:
· Registered
The base Base RSX model in Canada weighs 115 lb less than the Civic SIR, so I imagine that would give it an edge. The RSX also has 9 lb/ft more torque at 4000 rpm vs at 5000 rmp.
· Registered
i beat civic si's left and right... old 99-00 and the 02+ up. base rsx wins with equal mods and stock for stock IMO. i have seen very very many civic si's run low 16's. like 16.1's some are in the high 15's though.
good luck
Nick
1 - 20 of 166 Posts
