1 - 10 of 10 Posts
Special Olympics Winner
Alrighty i searched around to make sure this isnt a fail repost but i need to know if my battery is dieing or if its my alternator. What happens is when my car is sitting for a long time when i go to start it the starter really has to go before it will start once its running if i turn it off itll start normaly like the alternator is doing its job. It appears that lthe battery is loosing its charge while it is unused :noes:.
I have killed the battery twise and had to get it boosted left my lights on:shakehead. Im pretty sure its my battery but i would like your sides before i go pay to find out what it is.. It was a pretty cold morning today and it almost didnt want to start im getting scared to leave it for a week to go the USA and come back to a dead car.
Breast inspector by appt.
batteries don't like to be fully discharged. if you've killed it twice by leaving the lights on and it loses charge after sitting for a while, it's pretty obvious you need a new battery.
Yeah thought so my friends dad told me to try charging the battery to full with a seperate charger besides the alternator gonna give that whirl ..
EJ25 FTW
Battery is most likely fried. If the trickle charge doesn't *really* work, take it to autozone or some other auto parts store and have them check it/ replace it.
yeah car batterys run from like what 200-300$ right there not expensive are they
Maldito Goldo
sorry to crash the thread but,
What's the best battery for cars with audio systems so when the sub hits the light won't dim?
wow, first post, sweet...
A batt should not run more than $100, unless you are getting an optima or something like that.
Hey LT!
Eric
if a properly functioning alternator can't keep the battery charged, then using a separate charger won't work either. the battery has internal wear or damage in the cells and needs to go.
1 - 10 of 10 Posts
