1 - 9 of 9 Posts
Premium Member
BC Racing BR Type Coilovers
Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn't be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC's available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
BC Racing BR Type Extreme Drop Coilovers
Features:
  • Spring Rates: Front 10k, Rear 12k
  • Mono-tube shock design
  • Full height adjustability through shock body, not spring
  • 30 levels of dampening adjustment (compression/rebound)
  • Front camber plates are default on all applicable kits
  • Rear camber plates applicable on certain applications only
  • Custom spring rates available as well as a SWIFT springs upgrade available upon request
  • 1 Year warranty against manufacturer defect
  • Completely rebuildable
BC Racing BR Type Coilovers with Swift Spring Upgrade
Tech Specs:
30 levels of dampening force adjustments for compression and rebound.
BC Racing camber plates are vehicle specific and engineered to be rigid superior replacements to the OE Top hats. Our plates can reach 3 degrees of camber depending on the level of drop.
Each lower mount is designed with the OEM in hand to ensure OEM like fit and exact tolerance specifications matching OE manufacturers.
Premium Member
Discussion Starter #2
Features:
Premium Member
Tech Specs:
Premium Member
Discussion Starter #6
BC Racing 02-06 RSX RM Type Coilovers
Part Number: A-07-RM
Description
BC Racing’s inverted RM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover system we move the vital damper fluid away from the detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The inverted setup also handles high-g loads better and is much more durable under stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
Full height adjustability through shock body not spring
Full height adjustability through shock body (not spring)
Adjustable rear camber plates on certain applications
1 year warranty against manufacturer defect
Premium Member
Discussion Starter #9
1 - 9 of 9 Posts
