1 - 20 of 30 Posts
is John
best wheel spacer for DC5 ITR rims?
what is the best size for adding a wheel spacer for DC5 ITR rims (+60 offset) for fronts and rears? :ugh:
options:
a. 25mm
b. 15mm
c. 5mm
Absolute Pro-Formance
A. 25mm FTW.
is John
Discussion Starter #5
how long it'll last? coz i've read some thread that wheel spacers are bad... :ugh:
There's so much shit out there saying wheel spacers are bad, but 99% of the time when something goes wrong it's user error. Install them properly, and you will not have a problem.
is John
Discussion Starter #10
i have 15mm on mine. but i heard over time 25mm messes up your lugs and rotation :dontknow:
for real? are you having any rubbing issue on the inner side of the the fender well? so 15mm is the best choice then? :confused:
you're running 15mm on 4 tires?
Infinite Motorsports
15mm put more stress than the 25mm. The 15mm spacer you have to use longer wheel studs where the 25mm have its own set of studs.
is John
Discussion Starter #20
i know... that's why i sold mine and ordered a 25mm... don't want to replace the stock bolts and put the one included on the 15mm's... :thumbsup:
1 - 20 of 30 Posts
