1 - 20 of 37 Posts
NORTH AMERICAS FASTEST EP
check this out for a fuel system 2002 ep3 k20a2 gt3076r 500+whp.
I didnt have to sump the tank so far almost 200 miles no issues.
Very simple fuel system.
the pump-weldon 2025 -8 in and -8 out
plus side: all fuel compatibility.
down side: loud as hell and pricey, no fuel level anymore(tryin to fab something up though)
I had to re install the rear interior its so Fucxxxx loud.
-8 from tank to pump then pump to rail.
-6 return ( cause it was already done in -6)
fuel lab filter in front of pump.
1600cc inj
aem inj driver
fuel lab regulator
golden eagle rail
Tuned By Tony Palo.
sorry for the 2 crappy pics.
I did end up re routing the top feed hose underneath the pump.
I also ran the pick up directly over the top of the tank (not around like pictured) so its only like 4.5ft long and no walbro sock, weldon said thats a no no.
you have to run a very short return due to the flow of the pump. No lean cuts so far. 22-23 psi
Good for about 700whp on e85 and 1400whp on c16 So I was told.
Thanks to Philip from Race-lines.com
Discussion Starter · #2 ·
wow I thought this fuel system might help some turbo guys, guess not 38 views no commets, lol.
pretty dangerous if you get rear ended...
not a traffic driven car. Look how big the pump is, I couldnt find another spot.
Discussion Starter · #8 ·
Looooove your setup and car...let's get it in the 10's bro!!
thanx man and I promise im trying But damn its hard and you have to pay to play.
Q8 fastest SC CTR
lovely setup man:thumbsup:
BUY MY CAR!!!
im not seeing how its good. No offense but your fuel gauge should work no matter what kind of pump setup you have, you must have disconnected something by accident of the float is stuck in one position inside the tank with no room to move. Mounting a pump in the rear is dangerous for sure, most of us daily drive are cars. You also have a very long feed from the tank to the pump which is not the best for drivability. Im sorry but I do not see how this is anywhere near as good as the other fuel systems people run on here. But :thumbsup: to your for trying something different.
Discussion Starter · #12 ·
there is no oem part in the tank thats why the level dosent work anymore. The weldon can pull, lift, and push fuel unlike other pumps. I spoke with weldon they said 4.5-5 feet of pick up is no issue for this pump, thats why it retails for 800.00. remember it goes over the tank straight to the back where the pump is its not as long as you think. look at how much it cost for 2 bosch all the wireing all the fittings the 2 filters ect. It should be more than this system or very close. this is a simple race car style sysytem.
http://www.weldonracing.com/product.phtml?p=18&cat_key=6&prod=D2025-_A__(-8_inlet___outlet) ,maybe this will show you the difference from your bosch.
Discussion Starter · #13 ·
No fuel gauge won't work because he completely redid the whole intank setup. No float anymore.
thank you reading before posting.
how is it going around turns and accel and decel when the gas is sloshing around int the tank? my tuner and i are trying to decide on a set up to easily accomidate 700 whp and are thinking of using a weldon and a swirl pot, this set up if works would delete the costly and large swirl pot.
Discussion Starter · #15 ·
its been fine so far I drove a little today again, god its loud. The swirl pot will work but you may not need it, I would just be interested in finding a good place to mount the pump for those scared of being rear ended. the pump can be mounted vertically or horizontal.
I have yet to run the system too low on fuel for fear of messing up the pump or running out of e85 due to there is not a gas station at every corner. I think Ill fill up after every 125 miles.
Discussion Starter · #16 ·
plus you would still have 2 pumps correct if you do the swirl pot? super loud...
Discussion Starter · #17 ·
I even think by welding 2 small arms on the fuel alloy cap I have I could some how put the stock basket back in and use the fuel level again.
Discussion Starter · #19 ·
Discussion Starter · #20 ·
1 - 20 of 37 Posts
