1 - 10 of 10 Posts
What is the easiest way to route the boost gauge line through the firewall?
Theres a blue wire that goes through its own hole in the firewall. Just take the rubber gromet out and run it through there
riiiiiiight
XTRMRSX said:
Would the power brake hose be a good place to t tap the connection?
There should be a hose coming right off of the intake manifold, that's where you wanna do it...
for the boost gauge all u have to do is tap it in any vacume line off the intake manafold
Ran mine thru the BLUE cable, unpluck the rubber fitting..it runs inside the car...run it thru there!
Boostifed
what blue cable?
look at the firewall, there is a blue cable goin inside the car... there is a rubber boot...
1 - 10 of 10 Posts
