1 - 3 of 3 Posts
I want to install a boost gauge for my jrsc. How would I go about doing this? I know it's not needed but I want one anyways. Help if you can. Pictures would greatly be appreciated
All of the electrical you need to wire but for the boost connection. Look down between the fuel rail and the head. You will see two connectors. One closest to the battery will be going to the MAP sensor. The other should be plugged. That is where you will get your boost readings. All the other stuff is pretty simple.
and you'll next extra boost wire, the amount the comes with the autometer isn't nearly long enough, and somewhat shitty in quality....
1 - 3 of 3 Posts
