1 - 9 of 9 Posts
So the rsx I bought came with k pro !
My question is can I edit something to get rid of the lights on dash I have abs light on , air bag light on my main thing is I would like to know if I can activate the abs in the kpro I don’t have a upgraded differential so car pulls to the left when putting my foot into it I want to turn on till I get the differential
Last I checked, only dealership scanners can turn off the lights. If your ABS light is on, you have a problem that needs to be fixed. Same with your airbag.
You can purchase a TC module from Hondata to function with Kpro, but that ABS will need to be fixed.
Vaginal Lubrication Tech
<----this went in my homies turbo'd ep3. It didn't get rid of the torque steer.
If you're not worried about it, the lens for the gauge cluster pops off. Just put a peice of electrical tape over it & pop the lens back in. It covers the light completly & is barely noticeable. I'd use a razor blade & cut out a perfect circle or oval out of the tape. Put the tape on something & trace out around a marker cap?
Sent from my LM-Q710(FGN) using Tapatalk
Discussion Starter #5
Ok I’ll get that looked into then cause yea I’m not a big fan of lights if I can’t get rid of them and the air bag light I know it’s because he replaced the steering wheel !
Kpro
I am searching high and low to buy a kpro.:sleep:
I have a solution- Sell or trade me your kpro for my stock ecu so you have extra cash to diagnose and fix the probs. Let me know if you need any stock abs sensors or airbags i have 3.:fistbump:
1 - 9 of 9 Posts
