1 - 12 of 12 Posts
Ibredlightreving
lately whenever I stepped on the brakes my brake light turns on as if I pulled the handbrake up.. It just recently started happening and I have kpro.. Can this be an issue with kpro? What should I do ?
:ugh: did not the brake lights came on when you use the handbrake.
Don't pump gas or fists
you mean your dash "BRAKE" light.. not your actual brake lights..?
Pancakes
Check and make sure your brake fluid isn't low.
Doesn't Give A F*ck
yep
Sacked!!
The brake fluid is likely low. Do not top it off. This is a mistake made by many. Topping off brake fluid will not increase brake performance. The brake fluid will go low for only 2 reasons. The pads are low or you have a leak. Have the brake system checked. (actually a 3rd reason can be a problem in the cluster , but this is very,very unlikely)
1 - 12 of 12 Posts
