i really want to run a direct port 100 shot on my car...would i b able to with out kpro?
booomwelll am a give it a try and see how it goes..
I wouldnt run dry unless your Kpro, since there is no way of adding the needed fuel. I think with a Zex kit you can hook up a vacuum line to a FPR and it'll apply pressure to the diaphram in the regulator and increase the fuel pressure and adding more fuel through the injectors.what about a dry system? :ugh:
My setup. WON direct port setup. 100 shot for the time being.
Wow, my first post here.
Thanks for the kind welcome words.
The engine has approximately 230 HP with the usual bolt ons, but with stock ecu and catback. Add to that the 100 shot.
Up untill now I did approximately 80 1/4 mile passes with this setup without problems.
I want to install the hondata flashpro though. Right now as I`m writing this down I`m bidding on a used flashpro for sale on another forum lol. Hope this time I`m lucky.
