1 - 4 of 4 Posts
This may help: http://www.k-series.com/dtc.html
I believe 6-2 will be code 6, second listing: Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
If I'm correct, then:
6-2: Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
10-2: Intake Air Temperature (IAT) Sensor Circuit High Voltage
72-1: No. 2 Cylinder Misfire
119-1: not listed
15-1: not listed
12-1: not listed
11-1: not listed
You can double check the above by doing a free rental of a scanner from AutoZone or Kragen, which should give you the Pxxxx codes and I'd recommend before moving on. For the above listings, I'd check to make sure you have proper amounts of coolant in your car as a first step...
1 - 4 of 4 Posts
