Can someone tune my AFR for me please?
807 Views 4 Replies 4 Participants Last post by  himrin1216
I'm looking to crsx for help!!!! Attached is my calibration and two logs, one for second & one for a third gear pull. My AFR is actually higher than AFRCMD for the majority of the RPM range, but I'm getting a CEL saying the engine is too rich.
Can some one tweak the AF or tell me how to get rid of that CEL? It keeps coming back everytime I clear it.
Forgot my mods: I/RH/E/Kpro/JRSC 9psi pulley maxing out around 6 (06 S)/650 injectors
1 - 5 of 5 Posts
Can you post a datalog when you are not in boost? Something where you have gone through gears, and some cruising? You are running way lean, more than 10% lean in second. I don't think boost is where your problem is.
Someone else will probably chime in. If it were me, I would add 10 % to columns 9-13, in both high and low cam. I would also go to parameters>gear comp and add 6% fuel to gear 1 and 3% fuel to gear 2 on the fuel compensation table.
You should go to parameters>lean protection, and enable lean protection 1 and 2. Change lean protection 2 to 12.5-12.6. But if you do that before you fix your lean condition in boost.
You might try posting this in the supercharger chat thread, maybe someone will see it there.
Is 6 psi as high as you get?
luvmyrsx
pm mag .. pay him .. be tuned
1 - 5 of 5 Posts
