1 - 2 of 2 Posts
So I recently got this 05 Acura Rsx base model. It drove fine when I first got it but had one code about the throttle body Code P0122. After I bought a new battery that was fixed. Now my problem is I changed the spark plugs NGK iridium and oil car was running just fine still.. then onnneee dayyy I wanted to clean the throttle body so I took it apart and cleaned it very well...even bought new gaskets to make sure of no leaks..now I have a leak in the system somewhere and the car revs up and down...now the car will turn on and dies right after..😡 I’ve done everything I can think of and nothing I even bought a new idle air control valve and still nothing I don’t get it...it’s like I should of never tried to clean it...the only reason why is because it was idling always at 2000 rpm and I know it should be lower...I got it down to 1500 rpm but now I have this problem..please help when u can..
1 - 2 of 2 Posts
