I took apart my throttle body to clean the IACV in hopes that it would sort out an issue where my idle dropped too low. I think I made a mistake because when I put everything back together the idle is much worse.
Symptoms:
When I did the install I think I did a few things that may have caused issues:
I was torn between:
Symptoms:
- When I start the car, it revs up normally to nearly 2k rpm, but then dips down almost to 0 (nearly stalls), then bounces back up a bit
- If I give it gas it has the same issue (dips down to almost 0 / nearly stalls after I let off the gas)
- The car sounds raspier in the intake than usual
- Things smell a little off while it is running (though sort of hard to tell if that is new or not)
- Drained about 12oz of coolant by mistake / might have introduced air pockets
- I read afterwards there is a graphite seal you are not supposed to clean off, which I may have cleaned off because I was cleaning TB aggressively.
- My TB / IACV are also just very old (20 years) and the IACV seemed to get stuck even after cleaning. Wondering if I might just need to replace them.
I was torn between:
- Trying to bleed and replace coolant in case I caused an air pocket
- Buying a replacement TB and IACV from a donor (or new) and just replacing them outright, or maybe just a new IACV
- Taking it to a mechanic and admitting defeat.
