1 - 3 of 3 Posts
My 02 Acura rsx type S won’t start cranks but won’t start. The car ran great on a base map with the kpro v4 I just put on skunk 2 intake manifold and throttle body, 550 injectors, and bigger fuel pump car won’t start now fuel pump works and push fuel and the injectors fire but I know it’s definitely a fuel problem of some sort because the car will start if I spray alittle starting fuel in the intake manifold but dies out after few seconds.... Any ideas???
Did you install a fuel pressure regulator?
Did you change the injector size in Kpro?
Do you have a base map to run these parts on?
I can already tell you those injectors are unnecessarily large for bolt ons...
No I did not install a fuel pressure regulator, yes I changed injector size in kpro and base map was made and I went with the 550 because of a very soon too come turbo and the stock injectors are only good up too 5 psi
1 - 3 of 3 Posts
