1 - 20 of 27 Posts
I like turtles
I own a 02 Base Auto RSX and this morning i was on my way to school and tried unlocking the door and see that it wouldnt work so i had to manualy open it and to add to that the car wouldnt start up. So i concluded that the battery gone. After i got back from class i gave it a try and it started up. I checked the battery and everything was snug not a loose wire. Is this a common problem? Should i be worried or get anything checked? The car starts up with no light flickers or anything either.
EDIT: Shit happend again today :( new battery today.
And it did start up randomly serveral hours later
just jump start and drive it on the highway for a bit. i bet you started and stopped it immediately several times. the immobilizer in the car drains the crap out of the battery and if you don't leave the car on for a few mins immediately after starting it eventually it won't have enough power to start up..
Semi Kind of Retired
no time to drive the RSX
Sounds like you or someone else left something on or a door sightly open overnight.
Hi there
What? Untrue
I like turtles
Discussion Starter · #18 ·
off. if the battery died out wouldnt it not start again without a jump? because in my case it just randomly doesnt work and randomly starts working. buying new battery in a little see if that helps anything
Just had this problem sunday and today. Car worked all day sunday ( 3+ different times) then in the evening I needed to jump my car... drove it a bit, then came back and turned it off waited a few minutes and it started up fine. Since then, I haven't had any problems.
Went to work this morning and it was fine. Came out of work and I needed a jump...
I think one of my wires was loose so I tried tightening them a bit again. Hopefully that was it. It has started up twice since then no probs... we'll see if that was it tho...
1 - 20 of 27 Posts
