1 - 4 of 4 Posts
turbo
hey guys and girls, i just had the VIS xtreme gt hood delivered to me today and i tried installing although i ran into a couple problems....
1. there are no predrilled holes for the washer fluid hoses to be held
2. the holes along the edge on the front that hold the rubber gasket things
arent even close to being as big as they should be (drilled them)
3. the hole for the holder for the hood was way way too small (had to use a drill to make the hole wider)
also.....can anyone help tell me if the heat shield under the oem hood gets installed on the cf hoods???? i highly doubt it since there are two scoops on there but just want to make sure....and are hood pins necessary because when i push down on the cf hood it has a little play in it....thanks
i have the same hood and have had the same problems :) as for the washer fluid hoses, i cut the hoses since they were too long.. i didnt put in the rubber gasket in the front, and no you dont put the heat shield either.. as for the pins, ya i recommend you get pins for this hood,since its got the play you mentioned ;) btw get pics :)
post pics when you get a chance
:iamwiths: :iamwiths: :iamwiths: ;pictures: ;pictures: ;pictures:
1 - 4 of 4 Posts
