1 - 11 of 11 Posts
I'm having the first few mods done on my 03 type S this week by yosolo in northern Jersey.
I'm having new intake, headers, and exhaust put on (in addition to getting a kpro and tune).
One thing that I'm a bit concerned about is that I will no longer have a cat. He's telling me that I shouldn't have a problem with inspection being I'll have an O2 sensor.
I always thought a cat was a requirement in most states?
Anyone know if I'll have an issue with inspection in NJ? it's also possible I may move to NY at some point -- same question for NY inspection.
Thanks.
what header are you putting on?
if they don't do a visual inspection, you may be ok. if they do, you might get caught since they'll see the lack of a cat
Kevin★05 DC5-S
please please a header not headers headers super headers duper headers.
since you are worrying about O2 sensor and inspection, i assume it's a race header. like others said, if they dont do visual inspection, then you are ok as soon as car does not throw codes and CEL is not turn.
depend on what test they run in your state. Some do the 45me or something like that, were they hook a smogger up to your exhaust and read your afr. afr should be at 14.7:1 if you read anything below or higher they might fail you. There afew other test they can run but it depend on state. Just get kpro :D and tune depending on your state, some do 3000rpm or 4500 rpm for a set time. Set everything to that rpm for 14.7:1 and your set plus you can turn off the cel if you need to :shady:
cone head
A cat. is required in all 50 states (EPA Clean Air Act). I won't pass smog if they do it right, but you might get lucky and get someone who's lazy and doesn't look that closely. You'll still have to pass the sniffer test.
1 - 11 of 11 Posts
