1 - 11 of 11 Posts
Well, I have had a CEL on and off for about a month now. I thought it might have been the downstream 02 sensor, but after I scanned it today I found out it is a missfire in Cyl #1. I pulled my plugs and looked at them and they all look the same and all look normal. It seems to run OK for the most part but you can feel/hear a miss at idle though. Also, performance is down as I ran a [email protected] 98 with only mod being Hondata modded airbox. I went back to the track 2 times since then with Catback and K&N drop in and ran a best of [email protected] 95Mph.
Which one is cyl #1 if I pop my hood and look at the motor from the front of the car? I assume that coil pack might be going out or the plugs just need to be replaced.
Any help would be appreciated:thumbsup:
-Joe
www.magtuning.com
I assume cyl 1 would be the most left if your standing in front of the car
I doubt its a coilpack since you own an 2005, even if you owned an 02 I would be wary..
What grade of gas do you use? 87, 89, 91, 93?
How many miles are on your car?
Breast inspector by appt.
Cylinder 1 is closest to the crank pulley end, at the P/S pump/alternator side of the motor. The way to check is to swap the #1 and #2 spark splugs and see if the code switches to cylinder number 2. If no joy, then do the same for the coil packs.
yeah test things related to ingnition. more than likely its in there. could just be a bad plug wire.
The Vapor Unit
I had a cel come one and I had that same thing with the mis fire along with a problem I have to fix but, I will get some new plugs and see what happens with the mis fire.
speed demon
cyl 1 misfire
i had same problem on my 05 and it turned out that several valves were adjusted to tight from the factory . acura had to replace 5 valves that were burned . basically i had a valve job done they tried to blame my cai but they backed down when they found the problem . they found the problem with a compression test . suggest that you do the compression test
1 - 11 of 11 Posts
