1 - 3 of 3 Posts
so my car has a check engine light on..does any one know what good reader i can buy to see why the check engine light is on. thanks..
i have to get my car inspected but i would rather fix the problem before bring it to a mechanic..
i know that there is a driving cycle..meaning that if u drive the car for a long time the light will go off with out turning the car off..
Autozone will read it for you for free and tell you the code. There are plenty of readers out there for around 80-90; make sure that it's the kind that will clear them too. If you check my build ride, I've got a scangauge II mounted in front of my cluster that works well for me if you want a more permanent solution; it's around $170, IIRC.
1 - 3 of 3 Posts
