I've noticed that now its warmer my knob is stuck on the highest heat setting..you can turn the knob to the cold setting but only heat comes out..I know the whole unit in the dash is one piece..does anyone have any ideas?
Thankyou
Thankyou
its the blower motor resistor under the glove department. I had the same issue a couple weeks agoI've noticed that now its warmer my knob is stuck on the highest heat setting..you can turn the knob to the cold setting but only heat comes out..I know the whole unit in the dash is one piece..does anyone have any ideas?
Thankyou
Hello...so what did you have to replace? Were you able to do it yourself? I found a couple acuras in the junkyard and took out the control panel in the dash board, I tried a couple different ones but it didn't matter the heat is stuck on no matter what...thanks for your helpits the blower motor resistor under the glove department. I had the same issue a couple weeks ago
Go to page one here and download the free manual. It will show you those parts and a trouble shooting of it as well. There are so many parts that one persons success is anothers waste of money. The actuator to the door that closes off the hot water could also be unhooked or frozen, or the motor that opens closes shot. or the arm that moves it stripped.I'm on a road trip and its annoying driving across the states feeling the heat coming outta my heater even with it turned off...could use help asap like what can I replace myself, like the resistor you were saying....
