Hey guys, first post. I'm having issues with my 02' RSX type s.
Sometimes when backing up, the gear shift gets stuck in reverse. It takes serious muscle to push it out, however if I shut the car off, it pops out super easily. Sometimes on a cold start, I struggle to put it into 1st. Same thing, if i turn it off and it shifts like butter. After things warm up, there seems to be no issues getting into first. I noticed the other day, while trying to get it into 1st, if I forced it into 3rd or 4th, the car would jump a little bit. Almost like the clutch was still semi engaged. The 1st gear issue has only been recent, while the reverse issue has been ongoing for at least a few months.
Background:
In February I installed carbon lined synchros, and a competition clutch stage 3 kit w/flywheel. I have a hybrid racing short shifter and acuity shifter bushings.
I replaced the CMC with one from an em2 (new from Honda) just the other day hoping it might make a difference, no results. (Bled the lines)
Ive also adjusted my clutch pedal almost all the way out, so the clutch disengages within the first inch or two of pedal travel, no improvement. I can see at least an inch of slave cylinder travel when I have someone press in the clutch.
I know the clutch engages/disengages by parking on a hill, letting the car roll to a stop while in gear, and pushing in the clutch. The disengagement is very close to the top of the pedal travel, and the car rolls no problem.
Shifting through gears with the engine off is effortless. The trans makes no strange noises while driving (except for a bit of a rattley noise when engaging the clutch at too low of rpms)
I popped off the inspection cover half expecting to find pressure plate bolts or clutch springs but found nothing. I rotated the engine and saw all the pressure plate bolts still in their place.
The only thing I can think of is either the clutch plate sticking to the input shaft and rubbing against the flywheel while disengaged, or the pilot bushing providing friction on the end of the input shaft. I'm seriously out of ideas, please help!
Background:
