1 - 3 of 3 Posts
Hi I just bought a 2002 Rsx type s. This is a new problem. Whenever I press the clutch petal I feel/hear a ticking noise as soon as I press it, even when not in gear. Also when I engage 1st sometimes 2nd and reverse I feel a knock type feeling in the clutch petal. It doesnt make noise so I dont know what it is. I have already tried greasing the pin in case theres just friction but that didnt solve anything. Has anybody else run into this? What is it? What do I do to fix it?
Mileage? Do you know when/if the clutch has been worked on/replaced before? Have you checked the fluid level? Does the clutch only make noise when the car is running or is there a noise of some kind while you push in the clutch with the car just sitting i.e. not running. Does the clutch seem to have full range? As the clutch wears, it can cause the clutch pedal to shorten its travel. Thankfully it just sounds like you just might need a new clutch here soon along with bearings. Any issues while shifting are a whole other topic. Why not take it to a tranny specialist for a free diagnosis? Good luck.
Paul
Paul
1 - 3 of 3 Posts
