premeasuring does nothing. You haven't taken into accout the weight distribution of the car which is generally heavier one side. Just adjust the coils until you think they look even. DO NOT USE THREAD COUNT! If you want accurate measurements, change the height, drive to a completely flat surface like a parking garage and measure from multiple points (wheel well, jack points, etc).andrew84tran said:
And get it corner weighted before the alignment. Corner weighting will just throw off the height anyway, so my suggestion is to get them relatively even (just eyeball it), then get it cornerweighted, then aligned.
